SAT, Plenum, Intake question
chris6
Sorry for creating a thread for this. Does anyone know where the Satelite receiver is in an 05 FX. I have the SAT button on the radio so I'm hoping the receiver is already installed. It was in the trunk of my G.
I'm assuming thay my plenum spacer and Z-tube/Popcharger off the G will fit in the FX35. If not, please let me know.
Thanks guys for the help.
Chris
sat receiver, if you have one, should be on the back
pop charger and plenum spacers for a G will fit.
not too sure about the z tube
Z tube is the same, but thepop chrager location may not be the best. If your FX didnt come with SAT, then you dont have the receiver.
If there is a sat receiver connected pressing the sat button should put it on channel 1 I believe. The receiver is located behind the rear center seat on an 05.
Then you do have the receiver. You just need to find out the number and activate it.
I was leaning more towards wiring my ipod integration to it instead of the back of the radio.
i am a little lost in the same territory, but my problem is that when i press the sat button, it says no sat available. and i am still confused about the ipod connection here.
I believe your issue is that you're prewired for SAT but you still need to buy a receiver. There are some other questions about that floating around and also some good info on where to buy a receiver from.
Then I'll leave this for someone to answer who has a ipod integrated with SAT button.
