GTSPEC New 4 Points Mid Chassis Brace For FX35 (first Gen)
GTSPEC
Deer Park, NY
Hey all:
We finally finished the revision on our 4 points mid chassis brace for the FX35 (first Gen). Test fitted on a local FX35 (NY). Stock mounting points. No drilling required.
The final revision was a bit shorter but has better secure mounting points then our first prototype.
More detail / Spec on link here:
http://gtspec.com/product/gtspec-mid-chassis-brace-20032008-infiniti-fx3545
ETA: to be annouce. Possible delivery mid November.
Quantity: 20 pieces in bound, please contact your dealer to reserve them !
Price: $359
GTSPEC
631-586-3500
Just got mine installed.
Go thru B2AutoDesign. Charles works out a good deal for me buying this and 4 point ladder.
They're in Tampa FL. They're new sponsor here. ///11082
---------- Post added at 09:30 PM ---------- Previous post was at 12:14 PM ----------
The lowest point of the brace(rear crossmember) is about 2.5 inches from the bottom of the car as the brace is slanted rearward.
In pic below, the rear-end of the converter is about 1 inch in front of the front crossmember.
The front crossmember is about 1 inch from the bottom of the Invidia pipping. I know is hard to see in the pic
The rear crossmember is about 2 inches from the bottom of the Invidia flex pipe
My setup: 20" wheels, 265/50/20 tires, H&R springs. The Bottom of my car is 8 inches off the ground. The bottom of the brace is 5.5 inches off the ground. :eek: I may have to take it off during the winter months here in the Chicago area.
I am inthe shop and mine is getting installed right now... Also getting coilovers, spacers, ladder brace and front braces installed.... Can't wait.
---------- Post added at 09:57 AM ---------- Previous post was at 09:56 AM ----------
Almost forgot.... And the invidia exhaust
Nice combo!
I am not sure what happened but i ran into some problems...major problems
1) The exhaust did not fit...seriously did not fit, it looked like it was about two inches too long or somethingon the car(the cat converter was 2" too long" either way i needed to be two inches shorter
2.The mid brace also did not fit..it actually interfered with the flange on the cat converter
3)Installed the BC coilovers and the spacers, I had rub on the rear but not the front, I lifted the rear, from 1.5 finger to three fingers still rubbed in the turns....So I took the spacers off the rear....i need to figure out what is going on before I try it again.....
spent the whole day and all i got was the stereo system upgrade kenwood Nav/DVD, Two amps, subwoof box, and all around component speakers, diamonds and JL C5's awesome sound of course with a killer alarm, remote start, engine brace, front 4-point ladder brace.....
I was very disapointed aboutthe exhaust and the mid engine brace...
Has anyone had or know anyone who has encountered these problems....So close but yet no cigar...not a good day today at all....damn.
^^^ perhaps you can shoot Gordon a pm.. Stick with it, you'll figure it out. It's not called modifying for nothing.:wink (2):
