Programming Intelligent key FX 35 2005
Case Holland
Netherlands Nieuw Beijerland
FX35 RWD Invidia exhaust
Case
On one off the forums I read the suggestion that an ikey can be programmed diy by the following instruction:
Can anyone confirm that this works on an ikey lock/unlock and starting engine without metal key?
Note: The horn chirp can be disable by pressing the lock and unlock buttons simultaneously until the hazard lights flash, and no enable press the lock and unlock until the horn chirp.
To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.
1. Close all doors and lock all doors
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds.
(The hazard warning lamp will then flash.)
NOTE:
Key should be withdrawn from ignition key cylinder completely each time.
NOTE:
Do not rush the insertion/removal key cycling process. The side
marker/tail/license lamps and interior illumination will flash twice when this step is
accurately completed.
3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position
At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Press any button on the new remote controller once. (The hazard warning lamp will then flash) NOTE:
Do not press the button more than one time in the above step. If the button
is pressed more than one time, the programming procedure will not be successful.
The side marker/tail/license lamps and interior illumination will flash twice when this
step is accurately completed and programming is successful.
If there is only one remote controller skip step 5.
5. Additional ID code entry
Release the door lock, then lock again with door lock/unlock switch
(In power window main switch) 6. Remove key from ignition
7. Unlock driver side door, open driver side door and then close the door. (END)
NOTE:
If you need to activate more than two additional new remote controllers, repeat
the procedure on step 5 "Additional ID code entry" for each new remote controller. NOTE:
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore.
Thanks for answering:tup:
Nope. Won't work on the Intielligent key. Your choices are, bring it to the dealer and pay big bucks for 4 minutes of work, or start calling locksmith companies to see if they have the appropriate equipment to do the programming. Apparently some do.
I don't like the look of my 04 key fob. From my research 05+ have the nice sleek oval fob. If I buy one on eBay with uncut key, can it be programmed to my 04 FX by dealer or locksmith? Not too worried about the key cutting. Local home depot can do that ;)
Does your 04 have an intellikey? The "sleek oval fob" you're thinking about may be the intellikey. If your vehicle does not have intellikey, you can't switch from a regular key and fob to an intellikey. I hope that helps.
