F
Fire0nic3
Guest
ITB08048
This issue is specifically ONLY FOR THE FX50
- IF YOU CONFIRM: If an Applied Vehicle has the MIL 'ON' with DTC P1421 (Cold Start Control) stored in the ECM and There are no drivability issues, ACTIONS: 1. Refer to Step 2 in the Service Procedure to confirm this bulletin applies to the vehicle you are working on. 2. If this bulletin applies, reprogram the ECM. See this bulletin for further detail.
