Maybe, but problem with two sided tape is that one end sticks, but the other end would be covered by plastic....license plate vibrating against the light plastic might make some sort of noise and you wouldn't want to remove the plastic and make it stick obviously.
Need something that is very strong adhesive on one side (it's much stronger than some tape....these things are built to withstand years of climate changes and still are on there like the emblems are) and then rubber on the other side, which is what these OEM pieces are.
