abs sensor
calgary
i dont know if this fall in wheells and brakes or here, but it really is related to drivetrain.
I did wheel bearing 110000km on drivers side, and couldn't get abs sensor out, so it broke, does anyone know if i can use the Nissan Morano abs sensor, as its the same platform as the fx series? its about half price of the infiniti one? thanks :smug:
Not sure about the sensor, but the FX does not share a platform with the Murano. The Murano is based off the Maxima (FWD) and the FX is based off the G35 (RWD).
They are defenatly not the same as the Murano, Its too late for you but when I had mine done the tech cut the tab on the bearings old and new so they could be removed and installed without touching the abs sensor.
hello there. this thread is not too old but want to apology for this up. i just having the same problem and i dont know what to do. are you already find the answer for this one? thanks and hope to hear from you soon
If you google 'fx35 abs speed sensor', you will see some buying options. I bought mine direct from Infiniti dealership because I needed it same day, and paid about 170 I believe. There are cheaper options if you don't need it immediately.
Has anyone used aftermarket wheel speed sensors they are much cheaper but i doubt the quality of these cheap ones.
However to produce this part looks not to hard and many does it from china and taiwan
Case
