Swapping out stocks for 20's
WhoNoezFX
I just purchased a 2010 FX35. If I swap out my stocks for some chrome 20's (without TPMS), will there be a problem with that or will it mess up any part of the TPMS system. I have read some forums where all that comes on is the TPMS warning light that goes away after 30 seconds, but I still need further advice. thanks in advance.
i don't think it will mess up any thing other than you would not be able to check your tire pressure via the onboard screen.
you know you can always put the tpms from your stockie into the new rims. if it's not design for tpms you can drill holes for it, i think there is a diy in the diy section
+1. But you might as well put your current TPMS onto the new chrome wheels while your at it so you can still retain its functionality. Just make sure you install them onto the correct wheel location as before.
