Under section display
Pollekepol
Holland
Hi,
I have a problem with my display. Normally the "under section display", the bar at the bottom of the display that can e.g. display the song on a CD currently playing, etc., normally disappears. It normally only is shown if there is some new information to be reported (e.g. the next song). But since a couple of weeks it won't disappear anymore, it is there permanently. So it blocks the lower part of my navigation screen and that's a bit annoying. Any ideas?
Regards,
Robert
Infiniti FX45 in NL
There is a setting in the menu system that you can choose to change this display parameters. Look in system setup.
Mmm, I've gone over the settings in the menu system but didn't come across a display parameter for this. Do you know the name of that parameter and the value I should set it to? (mine is an FX45 from 2003 btw).
Under System Settings there is just 'Language' and 'Beep Setting'. The only parameter for the Under Section Display I can find is under the Display settings, where you can choose to either show Audio or HVAC information.
