IvoRoyfx35
- Cerritos, California
Do It Yourself on JDM VIP style Puddle Lights
Brought to you by: Ivoroyfx35 (Roy)
Product: JDM VIP style Puddle Light Kit sold by eliteautostyle@hotmail.co.jp (email & paypal)
Cost: $100 including shipping to US address
Tools needed: Power drill, drill bit, hole-saw, screw drivers.
Optional: A few fancy tools (see below), relay switch, wire terminal, splice wire connector, extra wires.
Installation time: 4 hours when sipping some beer and enjoying the installation. Probably can be done in 2 hours for you hard-core DIY people.
Warning: Always use caution as you are working with electrical wires. When connecting to the car’s electric wires, disconnect the battery to ensure your safety.
So, I’ve seen these puddle lights in person on a Z & lexus IS and they looked really good. The only concern I had on buying this for my FX was how it was going to look on a car that wasn’t slammed, let alone not even dropped. After many weeks of debate, I finally decided to just take the plunge and go for it. After many hours of research, I decided to go with JDM puddle lights from Elite Auto Style (I have no affiliation with this company). Several things set these apart from the other puddle lights that I’ve ran across. These were pre-assembled for easy mounting. The LEDs are made of high quality (based on the reviews I’ve read). The last thing I want is for one of the LEDs to burn out or change color, etc. That would be a major PIA especially with a flush install that I was going to do. The lights are focused and do not spread out like some of the other brands. And lastly, it arrives from Japan to my doorsteps in 3-4 days from the date of the payment. How can you go wrong with that?
Anyway, so here's a DIY on the installation process, and I took lots and lots of pics and tried to be very thorough. Hope you enjoy it as I've had a lot of fun doing it and wanted to share with everyone.
1. So I got the package and this is how the puddle lights came in the box. Nice chrome plates and the led bulbs had a thick coating of some sort, I guess for extra protection against rocks and all that good stuff on the road.
2. Back of the puddle lights…This is what I mean by pre-assembled. Some of the other lights I’ve seen online didn’t have these housings with screw nut for an easy flush install. Some just comes with 3M mounting tapes (Ewww). Now back to the ones I got, you can choose to use the mounting brackets that come in the box. I wanted a flush install because I don’t want anything sticking out of the side skirts as well as exposed wires.
3. Side Skirt Removal – Remove the screw located at the rear of the side skirt. I used this fancy tool that my friend had, but if you don’t have it you’ll need to remove the rear wheels because the space is too tight to work with a screw driver.
4. Remove these 5 screws located underneath the side skirt.
5. Remove this screw connecting the side skirt to the front mud flap.
6. Remove the three screws behind the front mud flap and the mud flap should just fall off of the car.
7. Pry apart the side skirt using a flat screw driver (cover with towel if you want, I didn’t and it was fine). I found that starting from the back of the side skirt (near the rear tires) was the easiest in taking these off. You’ll need to apply firm but gentle pressure. Once you pop the first two clips off, the rest will pop out pretty easily.
8. Here is the clip ‘housing’ that is on the car.
9. Here is the clip ‘insert” that is on the side skirt. Sometimes, it helps to use a thin screw driver to push down on this clip insert so you won’t break the clip housing when prying it apart.
10. I still managed to break a small part of two clip housings (red arrow)…But the skirt went back on fine and there was 0 rattle so don’t worry yourself too much if you break these.
11. Now comes the fun part for all you math wizards. Mark the side skirt so that each light has equal distance from each other and from the front and rear ends of the side skirt. You can measure the length of the side skirt and do some crazy math formula and figure it out yourself. For me, I just made sure that the distances between the lights were equal and the distance from the edge of the skirt was equal. Make sure that you are marking on a place that will be parallel to the ground once the skirt is back on the car (so the light reflected on the ground maintains the circular shape) and also make sure that your marks are in A STRAIGHT LINE!!! If not, they will look staggered on the ground.
12. Once you’ve made all five marks, drill a small pilot hole.
13. Select the right size hole-saw and drill through the pilot hole from the OUTSIDE. I think I used a 3/4" hole-saw, but make sure you measure your light base and drill appropriately. You only get one chance. (The hole can be slightly bigger than the base since there are tightening nuts for these lights.)
14. VERY IMPORTANT - Before doing anything else, grab yourself a cold one and pat yourself on the back for having gone this far without breaking anything.
15. Insert the puddle lights through the hole and tighten with the provided nut.
16. Connect the red wires together and do the same for the black wires.
17. Your packet should have 2 of the 10 lights that have only 1 red / 1 black wire connectors. These will go to the end of the side skirt. If you only have 1 or none with single connectors, (I only had 1) don’t panic! You can just tape off the ends with electric tape and you’ll be good to go.
18. All lights are now connected and exposed metal connectors covered with the rubber transparent cover. This is important as you don’t want any part of the red connector touching the black connector when the lights are on.
19. Put the skirt back on with the red/black wire ends out. Remove the side kick panel.
20. Remove the door step and say hi to the dried out bug that somehow managed to get in there.
21. As with the side skirts, gentle but firm pressure should pop the door step out without breaking the clips.
22. Now, before screwing the skirt back on, test out the lights. I used the battery of my drill to temporarily power the lights. Then, remove the remaining plastic parts near the side kick panel and lift up this black rubber/foam liner so you can put the wires through them and continue the CLEAN installation.
Follow the above steps for the other side.
23. Use the provided extra wires to connect the left side of puddle lights to the right side of puddle lights.
24. I used a flashlight to figure out where I can make the connection (underneath the dash).
25. A-ha!
26. I used another one of my friend’s fancy tools to carry the wire through this opening. But a coat hanger will do the trick just as well.
27. Connect the wires and tuck them in under the carpet.
28. Back on the driver’s side, cut the extra wires off and join the red to red & black to black. You can try to tap the conjoined black wire to the ground wire in the fuse box, but I just decided to ground the wire to the metal frame of the car (wire terminal sold at radioshack).
29. Now this is where you can go off on your own. You can certainly use the provided switch to create a switch that you can use to turn on/off the puddle lights, or tap into any 12v source such as side kick door lights, parking lights, etc. As for me, I wanted to tap into the doom lights. Then, the puddle lights will come on when I press unlock and go off when I press lock with the remote. It will also go on when the doors are open and go off a few seconds after the door is closed, as with the doom lights.
In order to do this, create a relay switch (radioshack) similar to the one shown here. I don’t know too much about wiring so my friend did this part for me, but it seems pretty simple. Put the red wire into the relay switch, make a loop with the white wire, and take the other white wire to the fuse box. Also take the blue wire to the fuse box to tap into the dome light wire.
30. Tap the white wire to the red wire shown.
31. Tap the blue wire to the purple/white wire shown. The purple/white wire is the dome light.
32. Make sure no wires are exposed and the newly created connections properly taped off with electrical tape / zip tie. Put everything back on.
This is how each puddle light looks with the flush install.
And inside the garage, with the dome lights.
I tried taking the picture out at night, but I didn’t bring my tripod so couldn’t take the pictures with proper night camera settings. You get the idea. I’ll take some proper night pictures later when I have the time. The lights look a lot better in person.
Thanks for watching/reading, I hope everyone enjoyed this DIY!
25. A-ha!
