Anyone know anything about Deeza (http://www.deezachassis.com/parts_tre.asp)? They make aftermarket tie rod inner and ends for our FX35/FX45. They are about 1/2 the price of OEM, which I believe is made by QSTEN (Part Number: W0133-1628483, Part Number: W0133-1628581).
My short research is that they make high quality products and there shouldn't be anything to shy me away from saving 50% from OEM.
Any thoughts?
http://www.rockauto.com/ (aftermarket)
DEEZA Part # INT608 More Info {Premium Quality} Patented Stronger Greaseable Version; Front Left Outer $23.79
DEEZA Part # INT606 More Info {Premium Quality} Patented Stronger Greaseable Version; Front Right Outer $23.79
Total = $23.79*2 = $10.22 = $57.80
Premium Quality Patented Design
New innovative patented design completely eliminates the problems of serviceable chassis parts infiltrating dirt, moisture and other contaminants into the internal cavity of the dust boot.
Tie Rod Body
One-piece forged body and CNC machined for perfection.
Wrench Flats
For ease of installation, the tie rod body has been designed with wrench flats.
Dust Boot
Designed for protecting the joint from contamination. No holes, gaps or valves. Elastic CR 60 material allows the dust boot skirt to bend out only when injected with additional grease.
Inner Bearing
Enhanced polymer bearing design resists radial/axial and vibrating forces. POM Material ensures low friction performance during changing operating conditions. Upper steel bearing increases the stud movement. Surfaces are modified by carbonitriding to reduce wear.
Upper and Lower Rings
Upper and lower dust boot rings are specifically designed to prevent dust boot tear. Acting much like a spring, they optimally maintain the correct clamping force and remain totally unaffected.
Ball Stud
The ball is induction hardened and its surface roughness is decreased into most possible lower level for smooth drive; SAE5140 material is hardened and machined for perfection and zero-defect, and as a result of this process its resistance to corrosion and break away is maximized. Warranty Information
Deeza 2 year/40,000 mile
vs infinitipartsusa.com (OEM)
4) OUTER TIE ROD
Outer tie rod, fx, right - power - POWER
03-07 $62.95 $47.21Outer tie rod, fx, left - power - POWER
03-07 $62.95 $47.21$94.42 + $9.99 = $104.41
QSTEN
Any thoughts?
Tie Rod Body
Wrench Flats
Dust Boot
Inner Bearing
Ball Stud
4) OUTER TIE ROD
QSTEN
