2010 Paddle Shifters
quick question when using
on my wife's GTI, i am able to downshift directly just using the paddle instead of shifting the gear to 'S' so i can make an instant downshift when to pass a car. is this possible or i need to shift to 'S' first in order to work the paddle shifters?
No need to shift to S :tonguey:
Press paddle shift "-" or "down shift" and it will downshift ,after you not use it for a few seconds it will go back to "D" mode automatically.
But if you do shift to S mode,it won't go to D mode unless you do so.
Does performing this mod really void your warranty? If so, that's a deal killer for me. I can't afford car payments and possible repair payments down the road. I'm looking to keep my FX for a long time.
What? It won't void anything. My dealership never even noticed that I added paddles shifters. :tongue (2): They are standard on 2009 FX35, so I doubt your service manager will even notice you installed them. They don't care ! It won't void anything,unless you f@@k up the installation and short something :tonguey:
Good luck ! :tup:
the Paddle Shift can not be installed on 2013 FX37 model, not sure for FX50
they did not comes with the bracket mount on 2013, and there no way to buy the bracket by itself :disapointed:
Fabricate it... there is nothing for at all for Gen 1, but many guys on here have them.... :good:
Well I open RipnFX 2012 FX35 Limited steering column. There are no bracket to mount the paddle. Ian (PMG705), where are you? Wanted to take a peek at your steering column to see how that bracket looks like :smile (2): Hoping to fabricate some bracket to mount the paddle onto > 2012 that don't comes with the bracket.
Andy if you can fabricate something I'm def in to get it done :)
i do not know how ^^lol
and certainly don't have right tools for it ><
---------- Post added at 12:33 AM ---------- Previous post was at 12:32 AM ----------
:good:
---------- Post added at 12:33 AM ---------- Previous post was at 12:33 AM ----------
:good:
I'm with you on that, neither did the 2012 and I have the Premium package. I have the parts looking at me and I'm looking at the steering column...where...the..F! are the mounts! GAH! Not even the front mounts...sighs..time to fabricate a mount, this will be my project now. I only hope that they did not remove the programming or the electronics part in the back of the AV unit...if they did...then I'll lose it lol! But the interesting part is the FX35 and FX37 comes in sports package with the paddles...so it seems they didn't want us to do a cheap upgrade ourselves...
---------- Post added at 01:33 PM ---------- Previous post was at 01:30 PM ----------
Only wish I had access to someone's steering column so I can see the exact difference and use that to align it correctly. Be easier but..if push comes to shove I'll figure it out...
I made the bracket mount for 09~14+ FX35/FX37/QX70 and EX35/EX37/QX50!
Also, I made the other bracket mount for M25/M37.
It is easily to be installed! Power Steering is not necessary to be removed!
The bracket mounts were already be installed on over 30's QX50 and QX70!
The bracket mount wil be selled with wire and connectors on eBay in 2014.
Sounds great, hopefully your bracket will allow all four mounting points of the paddles to be bolted on. Infiniti removed all the mounting points for 2012 FX models and up.
The bigger question is, did Infiniti leave behind the electronics/software to allow for paddle shifters?
Do you have any photos to show? Also it is 2014, so when you state you will have on eBay in 2014, please be a bit more specific.
