spshlfx
- Santa Cruz Mountains
Guys, is this part the exact same for FX35 and FX45?
I normally do it backward from the DIY. I loosen the locking jam nut first because its easier with the tie rod in place. Then go after the castle nut.
Thanks Zebra!!!! After reading this thread I'm a little confused on which part I should get? Is it Int606 for the passenger side?? Also another stupid question lol what would the sway bars be categorized under? I need a set of these. Thanks!!^rockauto.com
Lol I figured :disapointed: . Any idea on the sway bars?Passenger on your RIGHT(the right side).![]()
So you should get INT606.
What's wrong with the sway bar? Most of the time all you need is to replace the rubber bushing that mounts it to the frame. I can't imagine the sway bar would go bad unless you got into a bad accident or drive into a really deep pot hole that swallow half of the tire :smile (2):
Wow, in that case sway bar is in order. might want to look a closer look at the sway end link too.
Funny you say that :bomb::bomb: . I let my younger sis drive my car (stupid mistake) she ended up hitting the tires on the curb so hard that she bent the passenger side rim. So now my car is making like a clunking sound and the mechanic told me it was the sway bar and outer tie rod that needed to get replaced. My car is an 08 so I might as well do bith sway bars ? Or what do you suggest sir?
