F
Fire0nic3
Guest
Fire0nic3 or anyone else, what would you suggest to clean the inside pillars? They are dirty and not sure the best product and way to clean them? Reason I ask is I noticed that in any car when you touch this type of material or scrape it, even if your hands are not dirty, it leaves a dirty mark like these, so I want to be careful in how to properly clean these marks and if anyone has had any prior success.
thanks much!
With the material on our pillars, I wouldn't want to use anything abrasive to remove the stains. I also wouldn't want to use anything that's soapy or would leave a soapy residue.
Try this stuff:
http://www.homedepot.com/h_d1/N-5yc...splay?langId=-1&storeId=10051&catalogId=10053
I love Folex cause it's water based. Since it's water based it requires no rinsing which means it won't leave behind a soapy residue on the pillars or headliner. Another good thing is that it has no harmful chemicals that might discolor the cloth on the pillars. You can literally find it at any local Home Depot or Lowe's in the cleaning products area.
