Legal to Tint Taillights?
Poojap143
Lubbock, TX
Is it legal to tint your taillights in Texas??
and what are the specific rules and regulations to do either your headlights or taillights?
Please and Thank You,
Pooja :laugh:
Quote:
SUBCHAPTER E. GENERAL LIGHTING REQUIREMENTS FOR VEHICLES
§ 547.321. HEADLAMPS REQUIRED. (a) A motor vehicle
shall be equipped with at least two headlamps.
(b) At least one headlamp shall be mounted on each side of
the front of the vehicle.
(c) Each headlamp shall be mounted at a height from 24 to 54
inches.
Acts 1995, 74th Leg., ch. 165, § 1, eff. Sept. 1, 1995.
§ 547.3215. USE OF FEDERAL STANDARD. Unless
specifically prohibited by this chapter, lighting, reflective
devices, and associated equipment on a vehicle or motor vehicle
must comply with:
(1) the current federal standards in 49 C.F.R. Section
571.108; or
(2) the federal standards in that section in effect,
if any, at the time the vehicle or motor vehicle was manufactured.
Added by Acts 1997, 75th Leg., ch. 324, § 1, eff. Sept. 1, 1997.
that explains itself
Quote:
§ 547.322. TAILLAMPS REQUIRED. (a) Except as provided
by Subsection (b), a motor vehicle, trailer, semitrailer, pole
trailer, or vehicle that is towed at the end of a combination of
vehicles shall be equipped with at least two taillamps.
(b) A passenger car or truck that was manufactured or
assembled before the model year 1960 shall be equipped with at least
one taillamp.
(c) Taillamps shall be mounted on the rear of the vehicle:
(1) at a height from 15 to 72 inches; and
(2) at the same level and spaced as widely apart as
practicable if a vehicle is equipped with more than one lamp.
(d) A taillamp shall emit a red light plainly visible at a
distance of 1,000 feet from the rear of the vehicle. Can also be used against tinted tails(e) If vehicles are traveling in combination, only the
taillamps on the rearmost vehicle are required to emit a light for
the distance specified in Subsection (d).
(f) A taillamp or a separate lamp shall be constructed and
mounted to emit a white light that:
(1) illuminates the rear license plate; and
(2) makes the plate clearly legible at a distance of 50
feet from the rear.
(g) A taillamp, including a separate lamp used to illuminate
a rear license plate, must emit a light when a headlamp or auxiliary
driving lamp is lighted. Meaning dont change the color of the lic. plate bulb must be whiteActs 1995, 74th Leg., ch. 165, § 1, eff. Sept. 1, 1995.
Important parts there are the lic plate bulb must be white.
Quote:
§ 547.323. STOPLAMPS REQUIRED. (a) Except as provided
by Subsection (b), a motor vehicle, trailer, semitrailer, or pole
trailer shall be equipped with at least two stoplamps.
(b) A passenger car manufactured or assembled before the
model year 1960 shall be equipped with at least one stoplamp.
(c) A stoplamp shall be mounted on the rear of the vehicle.
(d) A stoplamp shall emit a red or amber light, or a color
between red and amber, that is:
(1) visible in normal sunlight at a distance of at
least 300 feet from the rear of the vehicle; and
(2) displayed when the vehicle service brake is
applied. Oops another possible tinted tail light loop hole
stoplamps on the rearmost vehicle are required to emit a light for
(f) A stoplamp may be included as a part of another rear
lamp.
damn more Tinted tail crap
Quote:
§ 547.324. TURN SIGNAL LAMPS REQUIRED. (a) Except as
provided by Subsection (b), a motor vehicle, trailer, semitrailer,
or pole trailer shall be equipped with electric turn signal lamps
that indicate the operator's intent to turn by displaying flashing
lights to the front and rear of a vehicle or combination of vehicles
and on that side of the vehicle or combination toward which the turn
is to be made.
(b) Subsection (a) does not apply to a passenger car or
truck less than 80 inches wide manufactured or assembled before the
model year 1960.
(c) Turn signal lamps:
(1) shall be mounted at the same level and spaced as
widely apart as practicable on the front and on the rear of the
vehicle; and
(2) may be included as a part of another lamp on the
vehicle.
(d) A turn signal lamp shall emit:
(1) a white or amber light, or a color between white
and amber, if the lamp is mounted on the front of the vehicle; or
(2) a red or amber light, or a color between red and
amber, if the lamp is mounted on the rear of the vehicle.
(e) A turn signal lamp must be visible in normal sunlight at
a distance of:
(1) at least 500 feet from the front and rear of the
vehicle if the vehicle is at least 80 inches wide; and
(2) at least 300 feet from the front and rear of the
vehicle if the vehicle is less than 80 inches wide.
Doesnt apply to our cars
Quote:
§ 547.325. REFLECTORS REQUIRED. (a) Except as
provided by Subchapter F, a motor vehicle, trailer, semitrailer, or
pole trailer shall be equipped with at least two red reflectors on
the rear of the vehicle. A red reflector may be included as a part
of a taillamp
(b) A reflector shall be:
(1) mounted at a height from 15 to 60 inches; and
(2) visible at night at all distances:
(A) from 100 to 600 feet when directly in front of
lawful lower beams of headlamps; or
(B) from 100 to 350 feet when directly in front of
lawful upper beams of headlamps if the vehicle was manufactured or
assembled before January 1, 1972.
One way to beat the tinted tail light ticket. i used this section and beat the ticket.
Quote:
§ 547.327. SPOTLAMPS PERMITTED. (a) A motor vehicle
may be equipped with not more than two spotlamps.
(b) A spotlamp shall be aimed so that no part of the
high-intensity portion of the beam strikes the windshield, window,
mirror, or occupant of another vehicle in use.
Thats for all your 4X4 guys. dont have more then 2 spotlights
Quote:
§ 547.328. FOG LAMPS PERMITTED. (a) A motor vehicle
may be equipped with not more than two fog lamps.
(b) A fog lamp shall be:
(1) mounted on the front of the vehicle at a height
from 12 to 30 inches; and
(2) aimed so that no part of the high-intensity
portion of the beam from a lamp mounted to the left of center on a
vehicle projects a beam of light at a distance of 25 feet that is
higher than four inches below the level of the center of the lamp.
(c) Lighted fog lamps may be used with lower headlamp beams
as specified by Section 547.333.
§ 547.329. AUXILIARY PASSING LAMPS PERMITTED. (a) A
motor vehicle may be equipped with no more than two auxiliary
passing lamps.
(b) An auxiliary passing lamp shall be mounted on the front
of the vehicle at a height from 24 to 42 inches.
(c) An auxiliary passing lamp may be used with headlamps as
§ 547.330. AUXILIARY DRIVING LAMPS PERMITTED. (a) A
driving lamps.
(b) An auxiliary driving lamp shall be mounted on the front
of the vehicle at a height from 16 to 42 inches.
(c) Auxiliary driving lamps may be used with headlamps as
§ 547.331. HAZARD LAMPS PERMITTED. (a) A vehicle may
be equipped with lamps to warn other vehicle operators of a
vehicular traffic hazard that requires unusual care in approaching,
overtaking, or passing.
(b) The lamps shall be:
(1) mounted at the same level and spaced as widely
apart as practicable on the front and on the rear of the vehicle;
and
(2) visible at a distance of at least 500 feet in
normal sunlight.
(c) The lamps shall display simultaneously flashing lights
that emit:
Just don't do it too dark. I feel like there are alot of trucks around that tint them black and get away with it so you should be ok. Texas is usually more relaxed with window tint laws, so I assume we can get away with lights just the same.
I'm going to take a picture of my tinted tails at 1000' and keep it in the FX for when or if I get stopped for them. I hope I can see them at 1000':rofl:
haha, nay man, i did have a lot of problems with cops regarding tinted windows, not on the tails though. The provisions above come from a jeep forum.
If they're illegal, they're illegal. My point was that Texas allows lower percentages when compared to other states.
you didn't say anything wrong stu.
with the dark window tint, i was being treated differently in two different counties.
you know how some cops have to be an arse about it.
Ok haha, misunderstood you it seems.
Actually this doesn't surprise me. I noticed that in Dallas, instead of Dallas police (city of Dallas), constables (dallas county) were giving out tickets more often. My last ticket in May '09 was from a constable. It was weird having to deal with the county for once.
Painting the taillights might make them not DOT approved and therefore no longer road worthy. Just my thought.
