Rear wiper problem
sirtrojan
Poland, Warsaw
2006 FX35 AWD
I've got one issue with rear wiper: it makes a lot of noise and stops after one movement /up and down/.
Should I grease it? Clean up the motor?
thanks for any suggestion!
rear wiper froze in the middle position. read the posts and checked fuses, was not the problem. thought it was a bad motor. took the elbow cap off the wiper arm, undid the nut and removed the blade. noticed slight corrosion around the shaft where the blade is attached. applied wd 40 and presto the shaft started turning. reinstalled wiper arm, works great. hope this helps
