power windows messed up! any ideas?
hey guys, i'm not sure when it started but i just noticed recently that my windows automatic up doesn't work anymore, when i press it to automatically go down it does, but when i pull it up it doesn't go all th way up. any ideas what might be wrong?
it's easy. Put the window all the way down. Then, hold the button up so the window raises. Once it's raised fully, hold the button for 5 seconds. It should be set
Or if you are good with tools, then grab a hammer and a chisel and then try to adjust the window level manually when it's up.
Let's call that the Russian solution.
