Clearance
The drop is more even than the pic shows, the front wheel is turned slightly. Need to put spacers back on the front, but the 15mm's I had were too much at this ride height. I'm thinking 10mm would be good, but I just haven't found the time to replace the studs. Tomorrow I'm going to trim the plastic a tiny bit more, raise the rear 1/2" and stiffen the damping a click or two.
Looking good. Do you have BC's or Megan's? More pics?
BC's, they go pretty low. I could bring the back down another 1.5" or so and the front 3" at least (without modding them). I'll take some pics tomorrow after I raise the car a bit and wash it.
Raised the car a bit and turned the shocks a couple clicks more stiff. Still rubs, but better. Also washed it since the weather was good.
Rear view, I like how wide the tires are.
How it fits after raising 1/2".
-2.5 camber from this ride height. Toe is correct so tire wear is fine.
Ride height after adjustment.
Inverted my subwoofer hitting harder then before
