Thats NUTZ....can't you just turn the car off in gear and set the parking brake? I plan on using an impact gun where i can.
Impact gun would be VERY useful... I didn't have one so I couldn't do INSTANT torque on the bolt. Trust me, nothing I did worked, I tried damn near every trick in the book. I even did a risky trick that didn't work so well:
Pull a spark plug, coil some nylon rope into where the spark plug was, turn the crank manually until the piston sandwiches the nylon on an up-stroke, then the crank will no longer turn freely allowing you to break the bolt free.
That didn't work, I didn't get enough nylon rope in there and I didn't feel comfortable putting any more in
Yikes.
I've always just had someone step on the brakes while breaking the crank bolt free on other cars. I don't see why you would even need a lift for the FX pulleys. There's tons of room in there...
An impact wrench would probably be best.
There's no need for a lift, and should be no need for the brakes if the car is on the ground (I didn't even put the FX on jack stands when I did it, like you said, tons of room). There's no way I could turn the crank hard enough to spin the wheels
As for another means of stopping the crank from turning... there isn't one that I know of. The way the automatic transmission works is basically two "fans" within the torque converter. One side is attached to the crank shaft the other is "floating" in the center and attached to the transmission's gears, while the housing surrounding this "floating" fan has fixed vanes that return the transmission fluid to the "suction" of the first "fan." There is no physical linkage between the crank shaft and the gears, so the crank pulley is independent of what the gears/tires/drive-shaft/etc are doing.
In essence, what I was doing when turning the entire crank was sliding the pistons up and down the cylinders, rotating the cam shafts via the timing chain and turning the first "fan" within the torque converter and pushing fluid through to the other side "fan" (turbine).
What I'm trying to get at is: no way to stop this thing from spinning unless you stop the pulley from rotating (get a friend to loop the belt around ONLY the crank pulley and pull hard while you turn the crank bolt), stop the crank shaft from rotating (shove something that won't produce debris into the cylinder to wedge between the head and the piston), or use a torque wrench to put an instant torque on it instead of gradual.
The other way around this is to make the BOLT not rotate while the crank shaft DOES rotate
Thanks for the correction Frankiago
. More information learned toward my FX. Appreciated. :.smile:
No problem! Forums can be great resources to learn from and at the same time petri dishes for wrong information to grow :tonguey:
PS: I used terms like "fan" to describe turbines and whatnot to provide a decent mental image of what's going on.
