FXsilverbullet
- calgary
So i had replaced my stock pads with the hawk pads and cross drilled rotors 55000km ago on my 2005 fx45 , now i have a metallic grinding noise from the drivers side wheel, the inside pad is almost down to metal, but the outside is about 40% and the passenger side inside and outside pads are at 40%. is the calliper not retracting back into it hole? is that why the drivers inside is worn out? If i need to replace the calliper im going to do both. next question is,..... i cant find any callipers any where but the dealer?
Does any other vehicle work on the fx series like the q45? or the g35? something must bolt up? any suggestions or constructive comments would be appreciated. thanks in advance.
:sad::ever:
