Exhaust tips. Ideas??
fxsty
Dallas
I want to get new exhaust tips. Any Ideas. Just for looks nothing Special. Everything is stock right now. I just want new tips cause the factory ones are dull.
yesssiiireeee
Motordyne makes two tips that you can use, I have on of the two.
mine are the 3" inlet 4" outlet rolled tip burnt titanium....
that is soooo sexyy ! :tup:
AHEM....copycat!
LOLZ
ahem
If you are going to go as far as changing your exhaust tips you might as well get a look that is very different from the stock ones (which look very nice on their own). Personally I went with Borla tips since they have an inner vent design that stands out from other tips. There is absolutely no change in tone or performance but you will definitely change the look of your rear. Check out some of their dual and square tips as well:
http://www.borla.com/products/polished_tips.aspx
Did you guys install them yourselfz. If so how did you guys do it. I'm interested in adding different tips and was wondering if an amateur could possibly attempt to do it by himself
Can titanium be safely welded to stainless?
I really like those tips you have JB... but I would only use one and I'd have to cut off the taper where it goes from 4" to 3"
I'm actually going to measure my exhaust tomorrow to find out... but JB could you get me a measurement on the top/farthest out point at the rolled tip side to the point where it tapers down?
I'd have to cut the plain ass end off of my muffler and have this welded on.
My muffler goes from like 6" muffler down to 4" tip, and the tip is super plain.
I meant for the first part of the statement to be an answer to the post, and the second to be what he should do lol
the titanium isnt welded to the stainless. the tip is made up of the tapered piece, which is stainless, and then a titanium piece attached to that with rivets i think....so the part you are tig welding is stainless to stainless...:tup:
