Worst Case Scenerio
Let me tell you where I am at right now and just be forwarned that it aint good...
After swapping out the thermostat then the water pump, then the thermostat again, I got frustrated and decided to take it back to the dealer. They originally believed that it was just an air pocket and performed the work. Got it back a day later and everything was performing great. Nice hot air was blowing in the cabin and I was happy as can be again. But as I drove back into my home town, 15 miles or so, the heat disappeared and the engine began to over heat.
Called the dealer right up and took it right back. They then performed alot of tests and believed that it was possibly the radiator being clogged. They stated that they did a combustion gas test on the coolant and it didn't give them any results that it may be a blown head gasket. They did test the radiator and stated there was a flow problem and swapped out the radiator.
After the radiator was replaced they test drove the car for a while and stated that once again, air was getting trapped in the cooling system and it was once again making the engine temp spike and spew coolant out of resevoir.
So I am now left with two options...
Replace the head gasket and hope that will do the job or just replace the entire engine... Either way, Its gonna cost me $$$$$... F***K!
So, I gotta figure out what to do and am requesting your help. New VQ35DE, Used low miles VQ35DE, Forged Bulletproof VQ35DE or Stroked VQ35DE???
Should I get the dealer to swap the engine out, or goto a performance shop? Not that many here in Jersey...
I was in the future going to upgrade to a Stillen supercharger for decent performance gains, but now with needing a new engine, it leaves the door open for everything...
Please help...
