this is a website I like to look at they have great articles on how to fix and manage some codes.
http://www.engine-light-help.com/check-engine-light-circuit-testing.html
P1105 MAP/BARO Switch Solenoid Valve
P1110 Intake Valve Timing Control (Left Bank)
P1120 Secondary Throttle Position Sensor (STPS)
P1125 TPS Intermittent
P1130 Swirl Control Valve Control Solenoid Valve
P1135 Intake Valve Timing Control (Right Bank)
P1140 Intake Valve Timing Control Position Sensor (Left Bank)
P1145 Intake Valve Timing Control Position Sensor (Right Bank)
P1148 Closed Loop Control (Bank 1)
P1165 Swirl Control Valve Control Vacuum Check Switch
P1168 Closed Loop Control (Bank 2)
P1210 Traction Control System (TCS)
P1220 Fuel Pump Control Module (FPCM)
P1320 Ignition Signal, Primary - Related Information
P1335 Crankshaft Position Sensor (CKPS) (Ref)
P1336 Crankshaft Position Sensor (CKPS) (Cog)
P1400 EGRC Solenoid Valve - Read Our Article On EGR Valve Codes For Help With This Infiniti Check Engine Light Code
P1401 EGR Temperature Sensor - Read Our Article On EGR Valve Codes For Help With This Infiniti Check Engine Light Code
P1402 EGR Function (Open) - Read Our Article On EGR Valve Codes For Help With This Infiniti Check Engine Light Code
P1440 EVAP Control System (Small Leak) (Positive Pressure)
P1441 VC/V Bypass Valve
P1443 Canister Control Vacuum Check Switch
P1444 Canister Purge Volume Control Solenoid Valve
P1445 Purge Volume Control/V
P1446 EVAP Canister Vent Control Valve (Close)
P1447 EVAP Control System Purge Flow Monitoring
P1448 EVAP Canister Vent Control Valve (Open)
P1490 Vacuum Cut Valve Bypass Valve (Circuit)
P1491 Vacuum Cut Valve Bypass Valve
P1492 EVAP Canister Purge Control/Solenoid Valve (Circuit)
P1493 EVAP Canister Purge Control Valve/Solenoid Valve
P1605 A/T Diagnosis Communication Line
P1705 Throttle Position Sensor
P1706 PNP Switch
P1760 Overrun Clutch Solenoid Valve
P1900 Cooling Fan
