Fenders in 2005 Fx 35
Suren
Moscow, Russia
Hi everybody!
What about making a project of side vents in old fx?
To make them look like Range Rover Sport's fenders.
I lookedthrough eBay and found Z3-style vents.
With them FX will look more agressive.
Any ideas?
One person has integrated the 2nd gen side vents into their 1st gen. I'll see if I can dig up that thread.
the only reason you should be doing side vents is if you make them functional like on the 2nd gen FX.
otherwise it's just a gawdy exterior piece that looks dumb in my opinion.:cool:
Yeah, that's exactly why I chose Liquid Platinum (silver) over any dark color. I prefered the darker shades, but I couldn't get past the vents. They look cheap, or like an afterthought. Almost as if they were just slapped on for no reason. FX50 versions slightly better.
the engine is cooled by air flow... air flows throufgh the grille & through the radiator which is made to disapate the heat from the engine through this airflow... this air is then forced into the engine compartment & then it escapes from below the engine compartment & under the car...
this design works very well at lower speeds & for a passenger car that travels between 5 & 60mph or so it's fine... the problem with this design is, it is easier to take this air in than it is to let it out at much higher speeds... at higher speeds this engine compartment air flow scheme winds up causing resistance to this airflow, & it almost acts like a parachute of sort... combined with the fact that all this air being forced out undernieth the front of the car also adds lift instead of downforce... which is why you won't find any big square nose & huge grille on something like a ferarri or other high speed performance car
fender vents & hood vents are designed to relieve this pressure, somewhat relieving this parachute effect & the lifting effect, but this really only comes into play at all at much higher speeds...
the difference they alone provide is claimed to be up to 5% decrease in wind drag, at what speeds I don't know... I agree I'd rather have the 5% loss & not have those vents myself:tongue:
can't they be removed, weld on a piece of sheet metal, sand and paint?
of course they can, that's called shaving... shaved handles were very popular for many years, vents can be shaved the same way really, but how many guys want to butcher up there brand new 50k car?
I am so totally in the middle of the road on this one. Sometimes I like the vents, sometimes they make me throw up in my mouth. I've never "loved" them, but I think I could live with color matched vents if they really did reduce drag and improve MPGs.
The 1st gen FX that put in the vents is ok - I think I would actually really like that vent style if it were color matched.
What about hood vents? Wouldn't they do the same thing for airflow? Would probably be easier to install than the sides too.
+1 on that. I'm not into side vents either, but if they are color matched and functional, than I can live with them.
I think hood vents are usually done along with fender vents... I think hood vents will give even less gains than fender vents but I guess a gain is a gain...
hood vents can be tricky because you need the vent to be in an area of airflow that creates a negative pressure in airflow for it to extract air, otherwise it'd either be stagnant, or even worse it could act as a scoop & do nothing to help... hood vents are usually done in the center of the hood or slightly foward of that, too far back & the pressure buildup at the base of the windshield will not let it be as effective...
one old hot rodder trick we used to do was remove the rear weatherstrip seal to the hood, allowing airflow through the back of the hood, although the turbulence in this area is high it still does help extract some air... the reason the factory seals this area well though is so if you had a radiator hose blow or something you wouldn't have a windshield covered with antifreeze, or worse even oil... but this is a small performance enhancement that can be done & aside from the danger of underhood fluids winding up on the windshield, it's a good thing to do... I used to always do this, haven't on the fx though...
Finally I made up my mind to do it.
Cost:
Work - $900
Fenders - $29 + Shipping ($10)
Sorry my friends that I can't post photos of accomplished work.
I think tomorrow I will be able to do it.
Fenders are now being painted and mounted..
