Hey guys!
A couple of days ago my original stock battery gave up - about time for a 6 yo unit. So I went to Autozone and picked up a brand new Red Top Optima, which is pretty much one of the best you can get.
While I was getting to install my new battery, about 7 hours had passed during which my FX sat without any kind of power.
I threw in a new Optima battery, the car started right up without any issues.
Now, this is what happened this morning - I went to start the car, the idling went up to 2,500 rpm and then suddenly dropped to '0' and the car stalled, I tried to start it again, it started but went down to almost zero, kept itself going somehow but sounded kind of lethargic.
Everything's normal while driving the car around - no RPM drops, no rough idling, but if it sits not running for more than 30 minutes, the same issues with idling creep up.
The only thing I changed was the battery - I measured the battery output and it's a full 12v. Needless to say, I checked the terminal connections for tightness - everything check out and I am puzzled at this point.
Could it be that the car sat without power for 7-8 hours?
Should I try ECU reset?
Should I just call it a day and go see my stealership?
Thanks for all you answers in advance!!!
---------- Post added at 10:03 PM ---------- Previous post was at 03:49 PM ----------
anyone?...
anyone?...
