Being in the market for a big brake kit, there are several choices for the 2003-2008 FX35 / FX45.
I'm trying to compile the information I found in one post so this may be useful for others. Please share your experience/knowledge as well.
*some pictures are generic, they are provided to just give an idea*
1) Brembo GT 380mm Big Brake Kit - 4 Piston (380 millimeters = 14.96 inches) ~ $3,606.00
Options: Red or Black Calipers, Drilled or Slotted Rotors.
Front Kit Only, No Rear Kit.
2 piece rotor
2) K-Sport - 11", 12", 13", 14", 15", 16" Rotor Front Kit (small 6 piston - small 12 piston) ~$1,500 - $5,000
14", 15", 16" Rotor Rear Kit (small 6 piston - small 8 piston) ~$3,000 - $6,000
$100 more for painted calipers in red and yellow.
Review:
http://www.ksport.co.uk/vids/Ksport-JP-July07.pdf
Off the UK website:
http://www.ksport.co.uk/products.asp?f=brakes
"When the components of the kit are worn, such as the brake discs, AP parts can be fitted along with the brake pads from the following well-known brands: AP, FERODO, MINTEX, EBC and PAGID."
Lightweight caliper at 5 lbs
2 piece rotor, curved-slotted is the only option
3) Rotora 6, 8 piston Front Kit ~$2,500 - $3,500
4 piston Rear Kit ~$2,000
for both kits, rotors = drilled and slotted rotors or slotted rotors
two piece rotors
4) AP Racing 13", 14.25" - 4, 6 piston Front kit ~$1,700 - $2,500
15" rotor, 4 piston rear kit ~$2,200 - $3,000
rotor - 4 piston is 1 piece rotor, 6 piston is 2 piece rotor. Can custom order 2 piece rotor for 4 piston.
options - cross-drilled and slotted or slotted
5) StopTech 355 mm x 32mm rotor, (355 millimeters = 13.97 inches), 4 piston, ~$2,700
rotor - 2 piece
cross drilled, slotted and drilled or slotted
6) Akebono (OEM) G37S/FX50S 14" 4 Piston Front ~$1,000
Akebono (OEM) FX50S 14" 2 Piston Rear ~$1,500 (must use Turbocad6's ball joint adapters)
Rotors = plain, 1 piece, unless there are aftermarket made for G37S/FX50S front and FX50S rear (G37S rear rotor will not work).
(pictures by turbocad6, hope you don't mind)
7) JBT
///3148
front
4 18" J-NS012F-4D L R/Bk/Sil/Chro 27 355mm 32 Slot/2Pcs $1,850.00
6 19" J-NS012F-6E L R/Bk/Sil/Chro 57 380mm 32 Slot/2Pcs $2,640.00
8 19" J-NS012F-M8E L R/Bk/Sil/Chro 44 380mm 32 Slot/2Pcs $3,550.00
8 20" J-NS012-8E L R/Bk/Sil/Chro 10 380mm 34 Slot/2Pcs $3,820.00
4 19" J-NS012F-4E L R/Bk/Sil/Chro 21 380mm 32 Slot/2Pcs $2,175.00
rear
4 18" J-NS012R-4D L R/Bk/Sil/Chro Bady 355mm 32 Slot/2Pcs $1,995.00
4 19" J-NS012R-4E L R/Bk/Sil/Chro 21 380mm 32 Slot/2Pcs $2,215.00
My thoughts:
I'm pretty torn in what to get.
Stillen has a great sale right now and the AP 13" Front and AP 15" rear looks good. Do I need to worry about the larger rear rotor?? The 6 Piston front is too much so that's not an option. I wonder if that would look weird with a larger Front rotor, not to mention the stopping bias. Wonder why AP made such a large rear kit when most other manufacturer did 14" rears.
The K-Sport has a great price, but no long term reviews and not an established as the other name brands. A few people I talk to that have run the big brake kit for 6-8 months swear by the kit and say for the price, no big brake kit can touch it since for the price of a 14" front and rear is the price of just a front kit. 2 piece rotors and many options for pads and rotors, enticing.
Rotora, good brand, but price of front+rear is a lot so not looking into this too much.
Akebono - not OEM quality, it IS OEM for G37S and FX50S. So high quality, tested and proven by Nissan/Infiniti. Downside is minor modification to install and not 100% bolt-on, closer to 95% bolt-on.
StopTech, great reviews, customer service. No rear kit is a downside. Would rather get Brembo for the extra money. Has matching rear rotors which is a plus since you can just paint the rear caliper.
That leaves me with Brembo GT. My #1 choice and even made my wheel purchase specifically to specification that they will clear the Brembo GT Front Kit. But, as with the StopTech, no rear kit!
No matching rear rotor, but the Stoptech rear rotor or Stillen rear rotor might be a close match. Rookie has a rear Brembo kit, but that's a one-off custom. Not to mention his one-off monobloc Brembo front...
Someone I know that worked in the industry of big brake kits and knows quality and the manufacturing being some of these kits, said his personal preference is to buy Brembo and nothing else. They have the very good quality and probably the most research and development, and testing that goes into each kit.
If you put it into context and the typical use is "street" use, the OEM Akebono Infiniti kit is the cheapest and the best choice in my mind.
What to do? Let's hear your thoughts, supporting facts would be great too.
2 piece rotor
Review:
Off the UK website:
two piece rotors
rotor - 2 piece
7) JBT
///3148
front
rear
My thoughts:
