Help please. I hear a hissing noise.....
TekneeK
Dallas, TX
When i start the FX i hear a hissing noise similar to air being released from near the rear passenger side wheel. Any suggestions on what it might be? No fluid is leaking. Just air noise. The car drives normal. At start the air hissing noise is noticeable. It even pauses for a second & starts hissing again. I know it's not the exhaust. The tire is fine. Can't be the shocks (hope not). I'm stumped....
maybe the fuel pump? try putting your ear on the rear passenger side seat or try removing the seat.... I get a sound from the same area with my upgraded fuel pump.
CEL didn't come on with the loose fuel cap?
No... Come to think of it that hissing noise is only when i start her up in the morning. I drove earlier today & i just went to check the noise. I still hear something but i'm guessing it is the fuel pump? But this time its not as noticeable & the pausing went away. I turned the fuel cap slightly to see if it was loose. It opened up but I'm not sure if it was tightened or if i untightened it. I didnt put any pressure in opening the fuel cap so i figured it might have been a bit loose. I will check tomorrow morning to see if the hissing starts again. But right now it's just a shallow constant hiss. Maybe i'm overreacting about the sound.
Check the PCV hoses for cracks or leaks. Any vacuum/suction line that has a hole in it would hiss. I noticed a hiss after I installed an oil catch can. Found the leak and replaced the hose - hiss was gone.
