wheel balancing
FX35_829
Cerritos,CA
2007 FX35
When i had my powdercoated wheels put back on they said they balanced my wheels but my steering wheels vibrates while i drive. Do I need to balance my wheels again?
if so anyone know any good spots in So. Cal and howmuch? Thanks !:tup:
the wheels shop balanced my wheels...u think they just misbalanced it b/c the steering wheel isnt supposed to shake/vibrate right??
thanks for the help bro
Ask them if the road force balanced them? I had a regular balance and it did not cure my vibration issued, but the road force balance did; special machine that I believe assumes the force/weight of the FX on the road.
Is it really necessary though? Are there such problems with the reg balancers?
Or maybe it's really after problem rides. I think new tires can go on well with the less tech ones, no?
GTO -- not necessary, but well worth it for hard to balance wheels.
With my new tires I got them done at a midas with a regular balancer. Slight shimmy at 60 mph, not enough to get them rebalanced.
My local shop has the Hunter and a special for $29.99 for all 4 wheels balance on the hunter. Slight shimmy is gone. The regular price I believe was $59.99 (this is just 4 wheels balanced, not to mount a tire onto a wheel).
So I don't think it's that much more expensive than a regular balancer so might as well get the best!
Wow did you just edit my entire thread including the title and certain posts, etc.??!!! Is this how this forum works?? That is some bullsh**
Guess it's a good option for bad vibes
Wasnt me, but we do that from time to time cuz we have some that are ESL & sometimes not worded well. If something was edited, it was likely done for clarification either in the thread title or for ease of searching.
last thing . . . relax & take a pill . . or try the other FX board & see if that works for you : infinitifx.org
+1, I had my wheels balanced and I had issues, thought it was the spacers, changed them still didn't work, thought it was the rotors, changed them still the same issue, then I decided let me go and get everything balanced again but at a different shop and the technician said you need to get Road Force balanced. All I know is I don't have any vibrations now.
I will also try the "Road force balancing" on my next set of tires.
I found on Hunters website, you can located local shops that have their equipment.
http://www.gsp9700.com/pub/search/findgsp9700.cfm
Any other machines used other than the hunter. The place I'm going to go charges $10/wheel and uses another machine but he says they do road force balancing just forgot the name of the machine. let me know guys. thanks
---------- Post added at 04:17 PM ---------- Previous post was at 04:15 PM ----------
oh yea he says its called C.O.T
