Ringo
- Los Angeles
Hello can anyone tell me which parts I need and how I can get them to get my rear hatch to remotely open?????
Remote on the key chain? Do 45s have a button on the fob that opens the rear hatch?
Ok good, I didn't think so.Not on the 1st gen, no.
You need the motor Carlos, #2 in that picture if the motor is out.
Actuator http://www.infinitipartsusa.com/par...FX35&year=2005&catalogid=1&displayCatalogid=0
If the actuator is going bad then it can be sporadic. But the cig thing I'm not sure, perhaps the navi unit is drawing too much power from the same line? Where do you plug in the navi?
I always plug it in there. But not charging anymore. The light turns on around the port, but no power. I am connecting it inside my center concole now.
im having the same issues with 909fx... rear hatch release button on the outside works every now and then, is motor or actuator or both? also my cig lighter rear seats does not work (fuse os ok)
yeah, but if you unlock your front passenger door, then the rear hatch opens. I forgot who on this thread mentioned it. Thanks for that advice. My front cig lighter is out. where is that fuse located? I need to plug my charger for my navi in the arm rest since the cig lighter is not working.
