Rear Hatch won't Open
On the inside(backside of the hatch), there is a little cover that pops off with a screwdriver, and it has a lever inside that should open the hatch manually.
No the only way the rear opens is from the inside using the hand lever. The button on the door and the remote on the key chain won't open the hatch. So I thinking it's the motor or sensor. Can anyone help or point me in the direction to buy one??
If the actuator is going bad then it can be sporadic. But the cig thing I'm not sure, perhaps the navi unit is drawing too much power from the same line? Where do you plug in the navi?
I always plug it in there. But not charging anymore. The light turns on around the port, but no power. I am connecting it inside my center concole now.
im having the same issues as 909fx... rear hatch release button on the outside works every now and then, is it the motor or actuator or both? also my cig lighter rear seats does not work (fuse is ok)
im having the same issues with 909fx... rear hatch release button on the outside works every now and then, is motor or actuator or both? also my cig lighter rear seats does not work (fuse os ok)
yeah, but if you unlock your front passenger door, then the rear hatch opens. I forgot who on this thread mentioned it. Thanks for that advice. My front cig lighter is out. where is that fuse located? I need to plug my charger for my navi in the arm rest since the cig lighter is not working.
by unlocking the front passenger door, do you using the key? i unlock all using my keyfob and still cannot release the hatch.
my fuse box is under the left driver side near the pedals... im guessing all fuses are there?
im trying to determine if all i need to replace is the motor?
You need the motor Carlos, #2 in that picture if the motor is out.
Actuator http://www.infinitipartsusa.com/par...FX35&year=2005&catalogid=1&displayCatalogid=0
