26" rims
lamar
Maryland
Ok Ok now I know everyone is going to say go with 24's or 22's but the bottom line is I want to put 26's on it (fx35). The tire size I am looking at using is 275/25/26 yes I know the ride wont be the best and yes I know it will be very easy to bend a rim. I looked around on here and I believe the guy "rookie" had 26's on his before in some magazine or something not sure though(if it was not his then it was one that looks exactly like his). I just wanted to know will they fit and still be able to lower it slightly? I have also noticed alot of you guys that are running 22's are running a pretty beefy tire I know to get a better ride quality and protect the rims. I just said that to say the 26" tire size I was looking at is not far off overall diameter wise and actually more narrow than the tires some of you are using. So can "rookie" or anyone else chime in and shine some light on this...........THANKS.
P.S. If you just cant resist to bash me and my idea go ahead I have tough skin! LoL , so ALL replies are welcome :tonguey:
I have to see how long you'd last with those wheels when you are actually using the wheels on the road.
It's your car and your money. No one will bash you for your personal taste and how you spend your money.
Post pix when you get them! :cool:
Rookie had those on for sema, the car was on display for a booth, but I recall him saying that he couldn't manurver the car and had to raise the car (via air bags)
O dang I was about to say I have seen one in person that had 26's and like 2 on the internet that used a taller 26" tire than I mentioned and were stock height. Needless to say I thought they looked fugly but in my mind I said with the right rims and a smaller tire so it could be lowered some it would look good. But now that you guys say that sema car couldnt even be driven that changes my mind real fast.........Dont want a monster truck sitting high! LoL.
The other option I was looking at was Asanti's new ELT 144 series rims in 22's or 24's that have a LARGE LIP.........any opinions?
I tried to post a link to the rims I am talking about but it says I have not made enough post to do that yet :-/
I think the fx would look good dropped with 24.. The only thing is I don't know how it will perform or the problems thatit will bring along the way.. But if you not into performance and more into look I would say go for it bro.. Post dome Picts !!!
your best bet is to try n meet up with someone with 22's because although they look small for the fx dropped or not the ride is harsh with the 22's on 35 series tire so I couldn't imagine 24 on some rubber bands (kind of scary) 24's can be done but your gonna need some fender rolling. If I can get some 24's with the same tires I then I think it will be okay. do a search though there are a few with the 24's mostly cali.
the fx uses a stock outer diameter of the wheel assy as 30.5"...
my general rule of thumb for a car to not look like it's sitting too high is the gap between the tire & the fender should never be more than the side wall height... if the gap is = to or less than the sidewall height then it looks good...
a 22" wheel with the equivelent diameter is going to wind up with a tire sidewall height of like 3.4" or so, so that's like 3.4" from the edge of the rim to the ground... reason is the lip of the rim is actually around ~3/4"-1" on average, so a 22" rim will measure closer to 24" edge to edge...
this is about the most that is normally considered still looking functional & usable... & if the fx is lowered the gap won't be much larger than this 3.4", all's fine & all looks fine...
now you go & step this up to a 24" rim & your taking away another inch from the sidewall... now your down to the rim edge being less than 2.4" off the ground... the overall look is just not enough tire... the wheel gap will now be larger than the sidewall height... this gives the apperance that the car needs to be dropped some more, looks too high... if you really slam an fx over the 24's it probably wouldn't look so bad, but will it still look functional & correct?, that's opinion... I think 24's look to big unless your bagging it personally...
now you go & step this up to 26"... your left with less than 1 1/2" between the rim & the ground...~1.3-1.4" sidewall. that's like a rubberband around the rim... so now the overall apperance is a giant rim with no tire... at that point it really better be slammed with no gap above the wheel at all for it to not look like a donk...
also, keep in mind that these measurments are not taking into account the slight flattening at the bottom of the tire from the weight of the vehicle, so the actual distance between the edge of the rim & the ground will be slightly less than these sidewalls listed...
only fx I've ever seen that 26's are going to look good on is rookies... to do 26's & not have it look like a donk it better be slammed & laying rocker on the ground... 26's on an fx with just standard lowering springs will look rediculous to most people... the idea is to create a look that most will look at it & say wow, that looks sick... to me the sickest your going to pull off with a normal fx is slamming it on 24's... or just lowering it on 22's...
now of course, most of this, besides the actual measurements, are just my opinion, but I'm guessing that's the point of this thread is for those opinions... I think most peoples opinions of 26's on an fx is NOOOO!!!! but then were back to, it's your car, & in the end about all that matters really is if your happy with your car... but if your looking for something that is going to look sick & not just stupid to most people, I'd say no to 26's... if you really want it to look "right" with 26's then you need to make the body look like rookies, that looks sick on 26's, but then you want it to be drivable too?... average fx I'd say the most you can do & not look stupid to most people will be 24's & slammed... but it'll ride like crap...
this is why most will say 22's are as large as you should go... it's the largest wheel that will still look right without bagging it & still ride decent & be functional...
Thanks Jeff, I'm actually heading out of town & surfing via BB
funny thing is, finish off the quarter glass chrome trim & replace the circus wheels with nice wheels & it would be a beautiful ride... ok, maybe the fender blinkers would have to go, but not a bad looking fx really...
