DDM Tuning HID Fog Light Kit
left fogs from ddm is out
Before calling DDM, switch the bulbs around to confirm if its the bulb or the ballast. If it still doesn't light, then it's the ballast. If it's a bulb, your going to have to send both of them to DDM. They will send you a new one after they test it and confirm the bulb/ballast is bad.
the first time it went bad for couple of days then it cam on again, but now it died again, so ill definitely do what you said
Does it stay off if you have the headlights on, and turn the fogs off and then back on? Make sure everything is connected well. One of my headlights went out because it came loose.
Well I installed mine today. Everything went smooth. I didnt have to remove he bumper as I thought. Just droped the bottmom belly cover, removed both wheels and liners. The right fog is a bit difficult to reach because of the windshield cleaner tank but it's doable. Left side is wide open
---------- Post added at 08:34 PM ---------- Previous post was at 05:06 PM ----------
Here is a quickie pic. They match very closely with the stock HIDs. I also have the turn signal/DTRL swap mod with Cree LED bulbs in the DTRL. Fogs are 4500k 35w
Looks great! Good job.
Thanks. Those really bright lights at the outside ends are the Crees. Very bright
Looking good.:tup:, all the bulbs matched very well. I'm surprise that the 4500K fog match up good.
so rain had corroded the ballast connection to the reley,
i disconnected and cleaned the 2 metal heads. Amazingly it worked! they started...
These ballasts are pretty good, the ballast was loose from the double tape and it had been flying everywhere while driving, impressively still working
Awesome. I think im going to go with the exact set up. Did you get the Slim kit or the raptor kit? 35w or 55w?
The Halogen fog lights are boring as hell. Your setup looks real clean.
I got the 4500k 35w. They're a bit "bluer" than stock but I hope they'll color shift the next couple hrs. I got the slim kit. Btw dont get 55w it's going to get too hot in the small fog housing
Sure when I get off work. Light coverage of the road is better, nothing excessive but a noticble difference from stocks
Nope. All the stuff is included. I didnt even take off the bumper to install them. Just both front wheels and wheel liners. Although I wouldn't trust that double sided tape for
Mounting the ballast. Made my own metal attachments for a pemenant hold ;)
I tried that but the wires were not long enough. I mounted the ballasts under the headlight on the plastic part
Cool. I cant wait to see pics from the inside later on Sir21
This looks like a solid route. Price is about the same if not less than I would've spent on PIAA halogen bulbs.
