Coolant tank/container?
I tried doing a search, but couldn't find anything that would answer my question. I noticed recently that my coolant container (the big white plastic thing next to the windshield washer resevoir) has a crack on it. I have an 04 so maybe its due to age? But anyway, my question is where can I get a replacement? I tried looking through infinitipartsusa.com, but cannot find anything close to a coolant tank/container. Would this be a part that an Infiniti dealer would carry/install? It looks like it wouldn't be hard to install. Any help would be greatly appreciated. And also, what is the actual name of this container? Thanks!
pretty sure its this one
http://www.infinitipartsusa.com/par...FX35&year=2007&catalogid=2&displayCatalogid=0
Reservoir assy - 3.5 liter - 3.5 liter
03-08 $75.88 $56.91
#10
not sure if any aftermarket ones will work.
Dealer item. You could do a temporary repair with some two part plastic weld--
Yes thats definitely something I could do in the mean time to prevent the coolant from leaking, but I do want to replace it to be on the safe side. I could get an aftermarket, but ours are mounted. I want to make sure it stays put and doesn't slide around. BTW, thanks to you to everyone who gave their input.
---------- Post added at 08:43 PM ---------- Previous post was at 08:43 PM ----------
That's because of the profile illustration, but that is the right part for you.
Ok thanks! I just wanted to make sure I was getting the right part.
Sounds easy enough. This may be a silly question, but should I empty the container before I start taking it apart? And since we're on the topic of coolant, any recommendation as to which brand I should use?
I would empty it...or remove the container tilt it and then remove the hose. I have been using Peak Long Life mixed with distilled water for a few months with no problems, formula of peak is very similar to Nissan's brand. ///4330&highlight=coolant
