Dtrls
dopie
Premium Member
Premium
Fountain Valley, CA
Alex
dude my dtrls on both sides went out and i switched it to the LED ones and now both of them arnt even turning on
wth?
like i put the holegen bulbs back in and they are not turning on
wth?
im bringin in my car to the stealership tommorow to see whats wrong but gonna ask you guys first
have anyone else have these problems?
no havnt been on lately sorry
most likely its the fuse cause i switched around the led ones and they have t - and + sides but it just wont turn on
weird
hopefully the stealership wont charge me
There are three boxes in the car. One in the foot area on the driver's side, and two under the hood on the passenger's side. The one that had the fuse in it was the one under the windsheild molding closest to the dash. I'm pretty sure it was 71. In the pic, it's the box open behind the battery. First red fuse on the left.
---------- Post added at 05:59 AM ---------- Previous post was at 05:52 AM ----------
^^ yup, that's the one. I blew that fuse as well when my angel eye inverters burned out.. Just replace the fuse and you'll be all set
im having the similar problem but mines only dtrl not dash, and parking light all toghether. What else can go wrong other than fuse?
humbertoCali had the same issues - maybe he can chime in as far was what went wrong
Hi, look at my ( 2005 ) is not same as your. Where else can I look at ?.
they all the same except the fuses box on top left corner is not there.
It's there, make sure you remove the black cover. You can see the cover in these pics...which is also a 2005 ///92
You have to remove the lower windshield trim to get access to that fuse box. And to reveal the fuses just pull up on the cover to remove.
Looks like you need to change your cabin air filter...:rolleyes:
Update.. Did you get this fixed....
You also have to be careful that if you do take your FX to the stealership change out the LED DTRL and put on the stock ones.
Yet it seems to me, just like it has happened to me, that you will only need to replace the fuse...
Thanks!
A huge thank you to you and all posters on this forum. You performed a valued public service. This not only fixed my problem but gave me renewed hope for the internet as a means of people benefiting humanity haha. Thanks again!
