SDMF
- Vancouver BC
Just want to confirm if this bulb will work on the EX.
The #7440 Stealth Bulb™ is an OEM replacement for your factory side marker bulbs. These bulbs often referred to as repeater bulbs are usually located on either side of a car or truck forward of the cabin to provide additional turn signal indication.
Bulb Specs: 12 Volt/ 1.75 Amp Single Filament Glass Wedge T 6 1/3 Type Bulb.
I just want to get rid of the egg-yolk look for the signal light. I think the EX will look better when this bulb installed.
I cannot post any link, but you guys can check out stealthauto.com if interested.
Thanks.
Thanks.
