it sucks, but i think i'll survive with it the way it is for now. with our economy, there are a lot better things i could think of spending $1,000+ on (hawaii anyone?) lol.
does anyone know how or have instructions or a manual on replacing the acuators?
Here is what I got from the .ORG
remove the three bolts holding the door finisher - one under the inside door lever and two under the silver door handle part.
work from the bottom and pull the door panel forward by hand - yes, by hand
remove all of the items attached to the door finisher which is the door handle lever, the automatic lock/windows controls and two wires. put the door finsiher away.
Remove the speaker (disconnect the speaker wire) and the large sticker - make sure you don't damage it. You'll need to put it back the same way.
Lower the window until you see the bolts through the two holes.
Remove the window bolts and then remove the window by lifting on th rear
Put the window in a safe place so you don't break it
remove all the bolts holding the window power assembly panel and gently put it on the ground - disconnect most of the cables by using a pair of pliers and pushing the clip through the hole
for the front drivers side, remove the rod attached to the lock by rotating the blue clip on the door lock assembly
remove the rubber stop on the door side and unbolt the door lock
while pulling the outside handle forward - carefully jiggle the door lock until you remove it
pull the outside handle up and pull backwards to lodge it (disconnect the intellikey wires if you have it)
unbolt the yellow bolt holding the baseplate in place
remove the three bolts holding the old door lock assembly in place (the repair manual says to replace the bolts - they have blue loctite on them...so don't strip them)
disconnect the three wires from the old door lock assembly and connect to the new
disconnect the power from the old door lock assembly and connect to the new
re-assemble in reverse order.
After you put the window in, reset the window before you put the door panel back on.
that's about it.
Hope this helps.
