Good eye Soon. I think you are right. They are directional and it looks like the driver's side rear tire is going the wrong way.nice clean red.
question: the Yoko parada a directional tire? they seem to be rotated.
I noticed the same thing about the rotors. The design of the drills should spin toward the front an it seems like that one on the front left should be on the front right no?
The PARADA Spec-X radial's all-season tread compound is molded into an aggressive directional tread design that features linked shoulder blocks, variably sized intermediate tread blocks and two continuous center ribs to combine acceleration, braking and cornering competence with a comfortable ride. A wide circumferential center groove and sweeping lateral grooves provide water evacuation to resist hydroplaning and increase wet traction. The tire's internal structure includes twin steel belts reinforced by spirally wrapped nylon to provide strength, uniformity and durability on top of a polyester cord body that enhances ride quality.
Depends on the internal vanes, rotor direction is based off the vanes not the direction of slots or holes.
I took a pic of my Yokohama Parada Spec X showing a close-up of the arrow (you can also see the direction of the tread on the shoulder.)Arnt there directional arrows on the sidewall?
http://www.tirerack.com/tires/BigPi...all&tireMake=Yokohama&tireModel=Parada+Spec-X
