This thread has been quiet for a while, but I just happen to be planning to paint my plenum this week - so it's a timely resurrection.
Yes, I could put the original cover on there, but to be honest, I really don't want to. Plan is to completely disassemble the intake from the filter all the way to lower plenum. I'll pull off the filter, wash it and get the plenum painted first so they will dry while I'm doing the rest of this stuff:
- Clean out entire intake interior surfaces
- Clean, dry & re-oil filter
- Clean throttle body & MAF
- Clean & paint plenum
- Swap out red hump couplers & clamps for black
- Rotate MAF 90 degrees down (hide connector)
Going to buy the paint & sensor cleaners after work today. Hope to do the work tomorrow or the next day. Already have the black silicone couplers & new T-clamps.
Since I've had the plenum spacer, I've enjoyed the FX a lot more. It definitely is one of the best bang for the buck mods, besides an Cold Air intake upgrade. I actually raced another FX with a half inch spacer and I pulled ahead of him from 40-80, but then he started passing me as we approached top speed. Of course, this was before some other mods. Now I'm pretty sure I could take him.
Thing is, top speed isn't real important to me in the FX. The VQ engine spends a lot more time between 1500 and 3500 rpms than it does at higher rmps. For my reasoning, the 5/16" is the way to go, unless you plan Forced Induction. If you are dropping the cake on a turbo kit, you might as well get an aftermarket plenum for FI that doesn't need the spacer. As far as I know, the best one out there is the Cosworth:
http://www.z1auto.com/prodmore.asp?model=350z&cat=intake&prodid=2842
The only other spacer out there I would have liked to have tried - only because I don't know anybody on the scene with it - the Altered Atmosphere angled plenum spacer. The logic behind the engineering makes good sense to me, though I haven't seen dyno numbers to prove it's any better than the flat spacers everybody uses. It's the most unique design of all the spacers.
http://www.z1auto.com/prodmore.asp?model=350z&cat=intake&prodid=1796
Oh yeah - and here's a current picture of my engine bay. I took a wire brush to the plenum and have had a few more mods done since the photos in this thread.
