Installed Today!!
The install took 15 minutes very easy!! The only hitch I had was that my 1/2" drive 17mm socket was missing and my deep socket didn't clear the muffler had to go buy one. That took longer than the install.
Took it out for a test run and could definatly feel an improvement on body roll.
H&R Springs next!!:tup::tup:
I did notice that the nuts were of the crimp lock type and the bolts are not through the crimp area of the nuts completely I'll be checking torque on those later to make sure they stay snugged should be OK.
No go out there and make us a snow drifting video hahaha (kidding)
those look pretty nice! How much torque we suppoust to apply to those bolts if you don't mind me asking?
48 ft/lbs for the upper
74 ft/lbs for the lower
GTSPEC Rear Lateral / Rear Lower Tie Brace - InfinitiScene.com :tup:
Update!!!!
Installed today thanks again Fred:tup::tup:
Nexr H&R's
Test Drive of Suspension Mods!
Took a drive today on winding mountain roads and WOW there was a marked improvement driving through the corners at a good clip with the GT SPEC- STB, Rear lateral brace, Rear tie brace and lower profile tires than stock.
Now when I go into turns at a good clip the steering feels much more responsive and stable.
To anyone looking to improve handling performance of their FX I would definatly recomend these suspension Mods!
Fun factor 10 View attachment 163198 -----H&R's will be next suspension mod.
Glad you like. Dont forget the front lowers also. Huuuuge benefits
