http://www.autopia-carcare.com/son-udmsfx-kit.html
[st][st]
10% off with code "autopia"
[/st]25% off with savebig25
[/st]30% off code = savehuge30
Hey Jeff
Looking to pick this up, got an upated promotion code? Thanks
Ton
---------- Post added at 10:22 AM ---------- Previous post was at 10:14 AM ----------
Jeff
Found it on Ebay for about $169. Thanks
Ton
You guys rather wool or foam pads for cutting?
I know you can use either, but which do you guys find easier?
That is the reason behind wool pads? I never knew that.
I just picked up the PC 7424 yesterday - and just finished my first panel with the Chemical Guys scratch remover -CG orange pad, and white pad with N3.
I am sooooo dam'd impressed. I can not believe what it looked liked after I finished it.
nice tip on the wipedown
Yes - thank you for the tip!!
I'm still on panel #1 on my Tacoma (haven't had time to finish) and I think I'm going to need a wool pad for more cutting power - and go back over it. I just ordered the yellow pad from Chemical guys - hoping that one will do the trick.
After putting a Halogen light on the panel (WOW - makes a big difference - you can see EVERYTHING) I didn't get all of the scratches. I don't even know if these will cut out - this truck was baad.
Trevor
