Stillen Intake kit with z-tube. That's the most common one which majority of the people on IS are using and proven to be reliable. Otherwise, you can try to contact LMS for their CAI pipe, then get the K&N RX4730 filter with a 3" straight coupler. The 3rd option will be the LMS SRI pipe - Z-tube (I don't know if they have it or not) with Stillen Intake kit without the Z-tube, then you don't need the coupler and you can use the stillen airbox and the stillen filter.
Either of the following options are good. It depends on your budget.
Stillen Intake Kit w/ Z-tube (about $250)
Stillen Intake Kit w/o Z-tube (about $200) - use the oem pipe (only changing the airbox and the filter)
LMS CAI with K&N Rx4730 filter and a straight 3" silicon coupler (about $200) - louder due to the lack of airbox (you will need to contact LMS directly for the availability of the pipe)
LMS SRI with Stillen Intake kit w/o Z-tube (about $270) - LMS SRI pipe (LMS z-tube) availability is uncertain (you will need to contact LMS directly)
LMS CAI with Stillen Intake kit w/o z-tube (you will only need the airbox) and K&N
RX4730 air filter (about $400) - (if you can sell the stillen filter then the price will be about $350)
All prices are approximated from my previous search about 1.5 month ago.
