intake?
there are plenty of intakes just for the 35, such as JWT, Stillen, LMS, Fujita, etc. also, you can replace the intake tube with a z-tube if the intakes themselves do not come with a new tube.
would the hks honeycomb intake work on my 2006 fx35?
or do i need to get a new intake pipe and all that?
or any other intake suggestion???
it needs to adapt to the MAF sensor (behind the stock intake box, piece has a wire attached to it). you can get an adapter of some sort. I never liked the HKS filter, always thinking it gets dirty too fast, and not enough surface area.
take a look at it, the MAF is screwed on with 4 screws (to the air filter box). that why Stillen and others have a venturi ring inside to screw into.
it looks similar to this
the black piece is the MAF and the MAF adapter is what connects to a filter or in Stillens / JWT case it connects to this
venturi ring is face the face, the other side is smooth
