updated list of speaker replacements
HYME
I was wondering if there is a updated list of speakers that will fit my 2006 FX35.
I know boston acoustics are pretty popular but I personally prefer a few others.
Not that bostons are bad, i like them, but prefer a few others. I'm looking at some
polk mm6501 that are 6.5" I think they would fit.
Another question I had was if anyone knows for sure the impedence on the stock bose speakers in the '06 fx35. I have read that they are 2 Ohm and I have also read that they are 4 Ohm so i'm lost. Is it 2 or 4 ohm or is it perhaps mixed 2 in certain location and 4 in another. I hate to ask questions that are already posted else where but this I can not find a sure answer to
If all you want is stock replacement many are choosing boston acustics. 3.5" up in front dash and 6.5" in the doors. Crutchfield had them listed if you want to see them or see the specs on them. You will have to search around for better prices.
Since most your speakers are blown i'm going to assume you listen to your music loud and would recommend component speakers and amps, otherwise you'll end up blowing your nice stock replacements as well.
Honestly I can't remember the Depths, up front it's not more than 1 3/8, same in the rear pillar area, and your doors won't be more then 2 5/16". the dimensions aren't deep in the front due to vent tubing etc... that is why so many refence boston, infinity, polk because they make shallow depth speakers. 4" speaker may fit but then you run in to having a speaker that is to deep in length. Your rear pillars will have to be modified a lil to make 3.5 to fit so that connectors don't touch the frame. Like HYME stated crutchfield does have a great size chart in most of their audio catalogs, I just don't have one in front of me but maybe I'll check later to update it here. below I've listed what most already know, sorry I couldn't help you more.
  • Front: 4"(3.5 will work best), 6-1/2"
  • Rear: 6-1/2", 4" (3.5 will work best
  • Dash: 4" (3.5 will work best) has 3 speaker placements (L.C.R)
  • Front door: 6-1/2"
  • Back door: 6-1/2"
  • Rear side panel: 4" (3.5 will work best) 1 in each rear pillar
I know they sell these on ebay
http://cgi.ebay.com/ebaymotors/Niss...025QQitemZ380066083256QQrdZ1QQsspagenameZWDVW
Description Of Item
Two Nissan / Infiniti Custom 1" Thick Door Speaker Spacers.
1 Bid = 1 Pair of spacers
Spacers are needed to fit aftermarket speakers in many Nissan and Infiniti vehicles.
These speaker spacers will work in the 350Z & G35. We have been told by customers that they will work in the Sentra, FX 35, M35, M45, and more. Please see pictures.
Since we haven't test fit the spacers in all the vehicles ourselves we offer a 100% refund if they do not work for your vehicle.
MDF Constructed 1" thick.
Uses factory predrilled holes for mounting
Comes with mounting hardware...nuts, bolts, washers, and lock washers.
Important...Please read
Please specify hole size on payment. Different brand speakers require a different size center hole.......Please specify hole size. We have these spacers available with 5.00", 5.25", 5.50", and 5.75" center mounting holes to accomodate 6.5" door speaker.
If center hole size is not specified you will receive a pair with a 5" center hole.
Remove your speakers and run them from there back to the head unit location. of course remove the lower dash to reroute your speaker wires
Well, when I get around to it, probably some time in January, I will add some 6.5" focal component speakers and mount the tweeters up in the front dash where the 3.5" would normally go. Then run the wire's all the way to the back (cargo area) and into an amp.
None of this will happen until i recover from christmas.
I did just get in a mrev2 and 5/16" spacer with copper iso therm.
I'll probably install it after christmas as well (torque wrench is on my x-mas list)
If noone give it to me i'm buying one!
I don't think it would make a big difference. Bose utilizes special circuitry that tailors the sound for each individual driver (similar to a crossover). The best thing you can do short of a full system swap is upgrade the source and/or amplification.
