Fastest you've gone in your FX?
  • Thread starter Thread starter Mikefx3508
  • Start date Start date
Status
Not open for further replies.
on a closed road of course..... I almost hit 140mph with 275/45/20's... so factoring the difference in tire size, it was probably right before hitting the speed limiter. I let off before going any higher.
here is a pic of viet's car from back in the day.
:err:
So far i've only hit 110 mph. i dont wanna risk my provisional license, i get my regular one next year.
:err:
What road was this on? I havent found a good enough freeway around here to do such a high speed.
wow u did 155 mph with the tire pressure light on? that's crazy!
90, I got a ticket the other day. So my foot's been light...
cops usually target cars they know are fast, so there u go, a fast suv. i usually cruise at 80, passing at 90. i saw this G35 that got pulled over and it was just going with the flow of traffic. cop usually hide on top of on ramps so they just merge onto the highway once they clock you, the also hide behind bridges, u turns, behind trees, etc. but unmarked cops r usually easy to spot: all black or brown tahoes, crown victoria police interceptors, chargers, camaros
The speed limiter is set at around 135mph, Viet's limiter was removed by technosquare(I think). Also he did not have low pressures...rather no tpm sensors or non registered sensors. I currently run without my tpms.
i've hit 110-115 i believe it was. would have gone higher another time, but i didnt know top speed in 5th gear is only about 110.
or unless he unlocked the governor by keeping a constant 45-60 seconds on the set speed until it unlocked
but then how do u explain the picture above? he was going 155 mph
Viet 155mph is possible and has been done as TS with the ecu reflash does remove the speed limiter. I have hit 140mph on the 210 fwy early one morning.
Status
