minkl81
- Beaverton, OR
I wonder if someone really have the 40lb version.
SSR Werfen GT-03 - 20 x 10.5 et43 Semi Solid Forged 30.8lbs
Strange, if somebody with an older version pre '05 wheel could weigh their 20's. Did you buy your FX used? I wonder if your 20's are knockoff's.
20x9.5 +45
20x10.5 +25
WHEELS ONLY
The front one weighs 26lbs and rear one weighs 28lbs.
What brand of tires are you running?STR 607
20x10.5" = ~34lbs
Total weight with 275/40/20 tire was 63.6lbs per corner. Tires are slightly undersized so they'll weigh less than OEM size.
I remember now from the pictures. I think he is running Michelin Diamaris.That's what I was wondering also, because that seems extremely light for a 20" tire of that size.
Sorry for my mistake, but the thread pattern is similiar to the Michelin Diamaris.Tires are Accelera Iota (another brand name for Apollo tires which also owns Vredenstein). I probably should have weighed tires alone, but I was in somewhat of a hurry. I'm 100% sure on the tire/rim combo weight. But the rim weight may be a little off since I had to try to balance it on the scale. Tire shipping weight was listed at 31lbs per box which is obviously an estimate as well. Keep in mind that my tires have overall diameter of 28.7" vs. 30.4" OEM. That will shave some weight. Same scale showed my old TSW setup at 75.2lbs for 22x9" w/ 265/40/22 tires.
