suspension ticking?
boarder0904
Vancouver
As the title says, i noticed theres ticking/clicking sound from the front left, while theres more weight on drivers side (when making right turns or passing the speed bumps with only driver side). I dont even know where its coming from i only can guess its from the suspension. Anyone exprienced this problem? any advise?
I hear ticking sometimes when I switch from reverse to drive, it sounds like an axle or something... I dont hear it all of the time though, only sometimes..
im not sure but i had the same problem. i went to my mechanic and he said the sway bar was broken. when i changed them, i never heard noises again.
I kinda have the same noise coming from the suspention as well. Specially if I slow down to go over a speed bump aroud 2-3 MPH. It sounds as if the springs are moving around
I don't know if this deals with suspension or not, but when i drive on local roads with the windows completely up and the radio turned off, I hear this squeaking sound when i hear a bump or run over a rough part of the road some sound like shifting styrofoam like that.
Any answers?
Any answers?
i get this too, usually in the morning when i leave for work. Mine comes from the window rubbing against the rubber molding all along the top edge of the window. it goes away as soon as i crack it just a little bit. i get some really aweful squeaks agains the bottom rear part of the window molding too against the glass. tried cleaning it with rubbing alcohol but that didn't help much.
Any answers?
Check your muffler hanger. I had that problem right after the warranty was passed. Apparently, the dealership said the rubber piece of my muffler hanger or something is wore. Just replace then then you should be fine. That would be the case if you hear squeaking sound from all over the car not from a particular spot.
I've had my o6 fx35 taken to the dealership in Infiniti of Chantilly. I showed them the TSB and gave me a QX for a loaner. Picked up my fx the next day and problem fixed. I'm glad my dealership did not give me excuses when I tried to have this front fender noise fixed.
