Stillen Exhaust?
toy4x
Premium Member
Premium
Hesperia, CA
04 FX35
Andrew
Someone has a single path Stillen exhaust up for sale from his G35. It does not come with the Y pipe though. Is this worth getting? Would I still need the G extension?
was the exhaust from a coupe ? ... then good. also the G extension is only needed is the exhaust was from a 350Z.
and like Eg3 said, the tips will need to be extended.
2 exhausts, both from coupes:
#1) Stillen single path catback, no Y pipe $300
#2) Magnaflow single path catback, Fuji Y pipe $350
I'm not going FI, so just going for good sound, but dont want to lose anything on TQ/HP either.
Magnaflow is 2.5 tubing also. But the Fuji Y pipe has 2.5" inlet, 3" outlet? how does this hook up? modding the magnflow inlet?
The stillen y pipe is the same as the fuji, so this must be pretty standard sizing.
Y will hook up fine but there'll be a reduction at Y-collector from 3" to 2.5". Fyi, if you're AWD, you won't be able to use both Y-pipes. I believe, standard FX y-pipe is 2.25" at the inlets and 2.5" at the collector.
