Stillen STB benefits?
Pupp
Premium Member
Premium
Shitcago
Guys,
What improvements did you notice from the installation of the Stillen STB? I know of the benefits in theory but did you actually notice much of an improvement on the road?
Thanks for any feedback.
i felt like i noticed a difference with my stillen. it seemed like the car could keep the intended path better. the example i think of is when i made a left turn and the FX didnt seem to go as wide as i was expecting. it followed the front wheels better, you could say.
I actually felt more of difference putting my rear GTSpec bars on than my stillen strut. I kind of wish I got in on the GTSpec fronts but was broke at the time.
Did you look at the GTSpec strut bar?
There was a gb that ended but you might want to contact them and see what price they can give you. ***GT Spec Rear Brace Introductory Pricing Special Part II*** - InfinitiScene.com
Thanks for all the info guys.
EDIT: I've decided to order the GTSpec. I will post up my thoughts after it's installed.
Another quick question: What coilover options do I have for a 08 FX35?
just installed my stillen stb & lms z-tube, will post pics soon, the stillen stb you can notice it more wrapping corners onto the hwy, sort of less body roll, the lms is just plain loudddd lol
None, unless you are willing to ship a set over from Taiwan where they have a set from Apollo. Do a search and you will see some info on them. rookie had them installed for bit but they were pretty firm.
Thanks. Guess I will start with some springs then, either H&R or Eibach appear to be the usual suspects for the FX.
Guys,
I installed a Stillen STB today, don't know if I felt anything different. I think after I install the rear braces I hope to notice something more. Im also thinking about ordering the front lower braces, maybe thats the trick.
Think about a table with 4 independent legs. Although the legs are connected at the top, it will still move a lot since they're not connected at the bottom. An STB is beneficial in a suspension, especially on hard cornering but without a lower brace, the suspension will still have play in it. The lower brace will mostly fix that. Doesn't matter that much if it's a really thick brace or not if you only have suspension bracing on the top.
