Question about momo shift knob.
yes, it does.
Swap is not hard at all.
+1.. install is easy. Simply:
1) pull down the lower chrome piece connected to the booth
2) You'll see a white piece with a small clip attached around it. Remove the clip and put it somewhere safe
3) Take out the shift knob
4) Take out the blue plastic piece (otherwise momo knob will stay too high)
5) Place the lower chrome piece of momo on the shift rod
6) Position the momo knob on the rod, tighten with small screws that come with it
Now, the chrome ring around the booth is rectangular and won't fit on the momo knob perfectly. Like here:
If you want it to look better like this:
Follow these instructions to remove the center console:
06-08 Clock Assembly Removal - InfinitiScene.com
When you remove the console, turn it upside down and flip the boot upside down. You'll see another clip holding the rectangular chrome piece in place. Remove the clip and the chrome piece will come out easily. Reassemble the center console, put the momo knob back and it'll look good..
i cut a hole in the one that fit snuggly around the piece that the knob goes over. i left it where the screws on the momo knob tighten around the factory shaft. this way they dont dig into the plastic, and has no chance of rattling or anything like that since the rubber fills the gab nice and tight.
when I tried to use one, the button did not function correctly. It was really snug fit and harder to get out. I used some silicon spray I had and finally got it out. I did not use it, but have it handy just in case I need it.
I did remove the blue stem piece on the shifter to allow it to sit lower.
it looks real nice now:tup:
