fogs on without headlights
brandhaylnoo
LA
does anyone know how to make it so that the fogs stay on when the daytime running lights are on and not only when headlights are on? I had my angel eyes wired so they thurn on with my daytime running lights and i wanted my fogs to be on at the same time. is there anyone who knows how to do this?
you can use that (which i had problems with)
or you CAN straight up hardwire them...but then they never turn off....which is what i did cuz i leave them on anyways :)
The kp technologies is the best bet because you have the control of keeping them on and when you start you car they will come back on the module is easy to install with a little bit of splicing but as long as you read the directions properly you will be satisfied. I have the mod installed on my fx45 and I love the look on people faces when i pull up and they see me with my fx with h.i.d. fogs on with running lights. Just search the org for better step by step instruction because the ones that come with the module sucks. and they talk about different colors.
Initially I had some issues cause the wiriring didn't match up. Worked through it with the owner of the module. Love this mod, and if you can work in the small space it will be easy. Follow the directions from "the org" and you should be fine. One thing of note is because wires on the KP Technologies module did not match up on my module, you may want to pull the module apart to see what is actually what.
KP Technologies Fog Light Module NOT worth it!
I would NOT recommend using the KP Technologies device if you have an '06-08 FX as the wiring doesn't match up at all. I had my local mechanic try to figure it out, then sent them JOHNMAX's write-up from infinitifx.org, and they still weren't able to make everything work. To make matters worse the company has no tech support number and doesn't reply to emails. I've read that it is difficult for the '03-'05 models, but nearly impossible for the next generation models. Their website shows the module for G35s and Maximas only. If you are able to figure out a way, please create a new write-up that we can all benefit from.
Wow thanks for that info.
My mechanic hard wired it and now I'm running fogs w/out headlights on. I can also individually turn on/off my fogs as well with the factory fog light switch.
com'on HanJo, get us the details. inquiring minds want to know :tongue: .
