- 2006 FX35 AWD
Yes. Thank you. I got everything installed and the brakes are so much better than stock.
Infiniti was wrong about needing the newer arms. When you go to order the newer rear knuckles they will tell you that you also need the newer arms because the ball joint location has changed. For this mod all you need to order is the knuckles.
:good: , seasonal modder = no issues.
